Date/Time: Sun, 08 Sep 2024 00:16:01 +0000
Disable certain orders in relation to current price?
View Count: 863
[2015-03-13 14:25:36] |
User51760 - Posts: 108 |
Hello Support Team, is it possible to disable certain orders in relation to current price to prevent orders made by accident? For example disabling the combination of a BUY LIMIT order above current price, which of course fills immediately by definition. I am aware something like this is possible for the Chart DOM - but I could not find an option for orders from the Chart Trade Menu or for orders in general. Thank you for your advice, Best, Chris |
[2015-03-26 12:41:28] |
I appreciate any input, thank you in advance...
[2015-03-26 16:32:52] |
This is not supported, other than on the Chart DOM: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartDOMSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-26 16:33:11
