Date/Time: Fri, 22 Nov 2024 18:43:25 +0000
can't find chartbook
View Count: 1832
[2013-05-29 00:34:32] |
User32512 - Posts: 25 |
i have a .cht on my desktop but open chartbook doesn't find it. i put it in Data and it still doesn't find it. how do i open it? |
[2013-05-29 00:56:27] |
Go to Global Settings >> General Settings. You will see "Data Files Folder". This is where you will want to put the Chartbook file with a CHT extension. After that you can open it from within Sierra Chart using File >> Open Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
