Date/Time: Sat, 26 Sep 2026 20:39:14 +0000
SC 1239 with problems
View Count: 1153
| [2015-03-11 19:11:22] |
| salsem - Posts: 43 |
Hello SC Support Amp /TTNet Message Log : TT FIX Trading: Received a FIX message missing required field SenderCompID <49>. | 2015-03-11 12:30:30 * FIX Message: 8=FIX.4.29=0004535=UAP34=49052=20150311-16:30:30.252146=010=045 | 2015-03-11 12:30:30 * TT FIX Trading: Received a FIX message missing required field TargetCompID <56>. | 2015-03-11 12:30:30 * FIX Message: 8=FIX.4.29=0004535=UAP34=49052=20150311-16:30:30.252146=010=045 | 2015-03-11 12:30:30 * TT FIX Trading: Error in received Position Report <UAP> message. Failed to get the value for the PosReqID <16710> field. Field not found. | 2015-03-11 12:30:30 FIX Message: 8=FIX.4.29=0004535=UAP34=49052=20150311-16:30:30.252146=010=045 | 2015-03-11 12:30:30 And in TAL: problems with statistics How are calculated market statistics? example yesterday on display with ES I had a loss of -$87.50, Today -$100.00 (without having traded) Thanks in advance |
| [2015-03-12 02:51:22] |
Those messages about the FIX messages from the TT FIX adapter occasionally occur from TT FIX Adapters. Disregard them. They are harmless. Refer to: https://www.sierrachart.com/index.php?page=doc/TradingTechnologies.php#CommonErrorMessages Market statistic calculations are documented here: Sierra Chart Market Statistics In regards to Trade Statistics in the Trade Activity Log, we do not provide interpretation or analysis of that data. This is your responsibility. Refer to the documentation here: Trade Activity Log: Trade Statistics Tab The calculations are all 100% correct based upon how the feature is designed and the order fills they are based on. The profit/loss value that you see is going going to be up-to-date based upon the most recent trade no matter when it occurred. Please refer to the documentation next time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
