Date/Time: Tue, 06 Oct 2026 00:31:10 +0000
FGBL downloading
View Count: 1855
[2015-03-10 21:12:52]
User63388 - Posts: 3
I have the same problem with downloading Historical Data for FGBL since mars month period.
Please don't tell me that the problem is.
Thank you.
[2015-03-10 21:30:04]
We need to understand what the problem is.
Posted image of the chart showing the described problem.
[2015-04-01 07:52:25]
Since 06 march day, I have a lot of problems to charge my graphs.
First, with FGBL market : I can't charge graph and it write a message "Sierra chart not answer"
Second, all my chart books are now no reached ( no accessible), so I loose all my graph configurations ... Message log is "error Windows 1392 / data no access and not read"
I don't understand what is happened because all was fine befor mars month.
I contact Infinity Transact and they answer me they change anything and my DOM infity is ok?
Thank for you answer
attachmentcopie ecran FGBL 01 04 2015.docx - Attached On 2015-04-01 07:51:38 UTC - Size: 193.63 KB - 611 views
[2015-04-01 08:22:07]
In regards to the image attached, there is a problem with the data in that chart. Go to that chart and select Edit >> Delete All Data and Download.
This only needs to be done once for each symbol. Do this for each symbol that has a chart that has a problem similar to the one you attached.
To open a Chartbook select File >> Open Chartbook.
In regards to:
Refer to this page:
http://www.sierrachart.com/index.php?page=doc/helpdetails16.html
Date Time Of Last Edit: 2015-04-01 08:22:37
[2015-04-01 08:26:39]
More information about my problems : Doc attached
attachmentcopie ecran FGBL 01 04 2015.docx - Attached On 2015-04-01 08:26:28 UTC - Size: 197.02 KB - 629 views
[2015-04-01 09:08:51]
Did you go to the Edit menu at the top of Sierra Chart and select Delete All Data and Download?
You must select this command from the Edit menu. It only exists there.
Also when providing us an image, only use the method described here:
Please do not attach a document file.
