Date/Time: Sat, 21 Dec 2024 16:50:17 +0000
Daily chart problem
View Count: 1118
[2015-03-10 07:25:02]
User31732 - Posts: 32
Hello.
I have a problem after rollover on a daily chart.
http://www.sierrachart.com/image.php?l=1425971858766.png
This is before rollover:
http://www.sierrachart.com/image.php?l=142597200967.png
SC V.1224 CTS T4
Thanks in advance.
[2015-03-10 08:29:35]
Update Sierra Chart to the latest prerelease with Help >> Download Prerelease and let us know if you still see this problem.
[2015-03-10 09:12:09]
The problem is still there.
[2015-03-10 16:33:28]
We are testing this now.
[2015-03-10 16:45:11]
The chart looks correct for us:
http://www.sierrachart.com/image.php?l=142600576456.png
Now that you are running the newer version of Sierra Chart can you post an image of the chart again.
[2015-03-10 17:10:51]
Now is all good. I've changed symbol like on your screen. Thank you.
