Date/Time: Mon, 30 Dec 2024 17:19:30 +0000
Different values in Delta of Bid - Ask V
View Count: 1154
[2015-03-09 13:11:38] |
nicktrader - Posts: 723 |
As you can see in the attached file there are two charts - M5 and D1. D1 chart contain "Numbers Bars Calculated Values" with focus on "Day cumulative AskV - BidV" = -1218 and M5 chart contain "Cumulative Delta Bars ..." with focus on sum = -609 Why do I have that difference. Shouldn't it be the same value? I am using an intraday data storage time unit of 1 tick Many thanks |
FDax 2015-03-09 13 40 19 Difference Ask - Bid V.png / V - Attached On 2015-03-09 13:08:16 UTC - Size: 28.99 KB - 376 views |
[2015-03-09 17:23:45] |
From our perspective, this is really impossible for us to answer. It is too vague of a perspective for us to even comment on this. Especially with the high complexity of what you are working with. We cannot provide an answer to this type of question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-09 17:29:45] |
Actually we think the problem is you are using the wrong Cumulative Delta Bars study. You need to use Cumulative Delta Bars-Volume.
[2015-03-09 18:49:38] |
I changed the study as you said in Cumulative Delta Bars-Volume and now all data are correct. Many thanks |
[2015-03-09 19:31:02] |
OK good.
