Date/Time: Sun, 04 Oct 2026 06:45:03 +0000
IB symbol for structured products
View Count: 2303
| [2015-03-08 21:29:35] |
| User77270 - Posts: 23 |
Hi, Is there a way to chart (and eventually to trade) structured products on IB via SC? For example knock-out certificates on the DAX, or certificates on the MDAX? And what would the SC symbol code be? The symbol on TWS looks like this: MDAX Structured Dec30'99 10383,791 CALL (DBCM, 0.001, Kein Nachlass) @SWB Thank you! |
| [2015-03-08 22:59:46] |
Yes, as long as the security can be specified as one single Contract unit. What is the security type? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-03-09 00:03:19] |
For example, let's take: Knock-Out Certificate on German DAX-Index ISIN: DE000XM10UL6 WKN: XM10UL IB Symbol: XM10UL Exchange: SWB Details: http://www.ariva.de/XM10UL If I can add "DE000XM10UL6" on IB's TWS, I get the current quote for the certificate, can trade it,... I also have market data permissions. But I don't know how to add it to SC. I tried XM10UL XM10UL-STK-SWB XM10UL-STK-SWB-EUR XM10UL-SWB-EUR and so on. But SC never found it ("IB error Code 366... symbol error.... unknow, unavailable or improperly formatted"). Do you know how to forma it? Thanks :) |
| [2015-03-09 17:08:49] |
Every security with IB has a Security Type. Contact IB and find out what it is for this. Once you know that, refer to the information on this page: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-09 17:09:22
| [2022-01-30 19:17:32] |
| User102394 - Posts: 9 |
Does someone by now know the IB symbol code for „structured products“ and can post it in this thread? Otherwise I will proceed by asking IB directly. Thanks in advance. |
