Date/Time: Fri, 22 Nov 2024 18:56:38 +0000
Labeling Peaks/Valleys on Volume Profile
View Count: 1567
[2013-05-28 18:33:57] |
agb1223 - Posts: 33 |
I am looking in my settings under volume profile to label the peaks and valleys much like a horizontal line or point of control, but it seems I cannot do this with the peaks/valleys. Am I doing something wrong or is this a bug? Thanks.
[2013-05-29 02:28:43] |
This is not currently supported.
