Date/Time: Mon, 25 Nov 2024 09:33:26 +0000
Extending Rectangle Feature Suggestion
View Count: 1826
[2015-03-05 23:13:40] |
Trader Ra - Posts: 87 |
Hey SC.. would it be possible to include additional options to how the text and price labels can be displayed such as centering instead of above or below only ie. vertical alignment? Much like how horizontal lines and rays have them already. 1. Text labels can either be in the middle of the whole rectangle (shading area) or centered on top/bottom border instead of above/below border? 2. Centering option for price labels as well on the top/bottom borders? 3. Possible option to have price displayed in the values scale like studies? Also, The option under Chart settings >> Draw Highlight Drawings Underneath Main Graph and Studies Can this option be split into two so we can choose whether we want it under main graph or studies. So a checkbox for each option. I want my zones underneath main graph but above all studies.. presently i cant do that. Let me know what's possible and what's not. Thanks for considering. |
[2015-03-06 18:19:58] |
We will have a look at items 1 and 2 only.
[2015-05-05 16:51:08] |
User25850 - Posts: 13 |
I second that request (items 1 and 2). Thanks Date Time Of Last Edit: 2015-05-05 16:51:38
[2015-10-09 07:07:13] |
Last response was from March as well. Options 1&2 are still not available. Was this looked at?
[2016-05-27 16:48:48] |
Al SC Developer - Posts: 434 |
In the next release, there are two new options for rectangle highlights: * Center Text Vertically - When set the text is split from the top label and centered vertically within the highlight * Center Price Labels On Level - When set, the price labels (and potentially the text) are centered on the upper/lower highlight level. These two options can also be set from ACSIL using UseTool. Date Time Of Last Edit: 2016-05-27 16:58:01
[2016-05-28 05:40:25] |
Yes these items have been looked at and some of them have now been done. You can see that we get these requests done even if you are not a paid user still. You can tell we have a long list of things to do because of the long-delay and that is why we have not been very responsive to some of your feature requests and could not comment when we were asked about them again because we do not know if and when they will be done. Also asking us about something that has been requested previously to see what the status of it is, is a burden on us. It takes is time to look it up, consider it again, and we probably in the end do not have much of an answer to give anyway. So if you are not happy about not getting answers to your questions, understand why. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-28 05:42:47
[2024-03-17 01:47:04] |
aseef - Posts: 49 |
Is there any possibility you can add option to "Centre" the label for a rectangle or a ray drawing horizontally?
