Date/Time: Sat, 21 Dec 2024 16:35:56 +0000
open chartbook menu does not load chartbook from subfolders
View Count: 1009
[2015-03-05 17:29:01]
yoytu - Posts: 59
is there anyway to get the old way ?
or is there any way to add folders to ths current menu because i cant open the chartbooks i have saved on individual folder
[2015-03-05 18:24:41]
We will see about adding folder support to the new Open/Save dialog. However, right now there is no way to get the old Microsoft dialogs.
We have had several reports lately of problems with those and they are very slow in some cases.
You need to move all of your Chartbooks into the Global Settings >> General Settings >> Data Files Folder.
[2015-03-05 19:21:08]
yoytu - Posts: 59
i am wuning on wine under linux if that matter
[2015-03-05 19:26:25]
No, that does not matter.
[2015-03-09 23:03:04]
birdaa - Posts: 12
I keep my chartbooks in OneDrive so I can open them from multiple computers and have them synced.
This is a key feature for me, is there no way to open chartbooks from a different location?
Date Time Of Last Edit: 2015-03-09 23:05:07
[2015-03-10 00:21:59]
Not now in the newer versions.
[2015-04-14 15:02:49]
yoytu - Posts: 59
before the 1241 there was a option to select a folder now is gone again
edit
my bad the pre-release build solve the problem
Date Time Of Last Edit: 2015-04-14 15:20:49
[2015-04-14 17:24:54]
Yes, use the prerelease.
