Date/Time: Sun, 20 Sep 2026 09:39:12 +0000
i cant get a russel mini quote to work on my charts from ameritrade
View Count: 1399
| [2015-03-05 16:22:06] |
| User89188 - Posts: 20 |
all my quotes work on my charts except russel mini.i get them from ameritrade and the symbol is /tfh5 .I can get the quote on ameritrade it just wont work on sierra. can you help me?
| [2015-03-05 16:54:41] |
| M5amhan - Posts: 468 |
you are getting futures through SC with TD Ameritrade? what package number do you use? (sorry no help just curious)
| [2015-03-05 18:25:51] |
Futures data from TD Ameritrade is not supported. This is explained here: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-03-05 19:13:31] |
Software version: 1220 | 2015-03-05 14:11:28 Uses Old Spreadsheets | 2015-03-05 14:11:28 Usage end date: 2015-04-05 | 2015-03-05 14:11:28 Enabled for: Advanced Features. | 2015-03-05 14:11:28 Enabled for: Advanced Features 2. | 2015-03-05 14:11:28 Enabled for: Sierra Chart Historical Data Service. | 2015-03-05 14:11:28 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2015-03-05 14:11:28 Enabled for: CME, CBOT, NYMEX, COMEX exchanges for trading accounts. | 2015-03-05 14:11:28 Received 1 data feed usernames. | 2015-03-05 14:11:28 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-03-05 14:11:28 Active service: TD Ameritrade | 2015-03-05 14:11:28 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-03-05 14:11:28 2015-03-05 11:11:28 Local computer clock time | 2015-03-05 14:11:28 2015-03-05 19:11:28 GMT time | 2015-03-05 14:11:28 2015-03-05 14:11:28 Time zone adjusted time | 2015-03-05 14:11:28 Time difference to server time: 2 seconds. | 2015-03-05 14:11:28 Program path: C:\SierraChart\ | 2015-03-05 14:11:28 Data Files path: C:\SierraChart\Data\ | 2015-03-05 14:11:28 OS Version Number: 6.2 | 2015-03-05 14:11:28 Locale Information: C | 2015-03-05 14:11:28 Checking for new symbol settings for tda | 2015-03-05 14:11:28 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-03-05 14:11:28 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-03-05 14:11:28 Symbol settings are up-to-date for tda | 2015-03-05 14:11:28 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-03-05 14:11:33 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-03-05 14:11:33 TD Ameritrade | Connecting. | 2015-03-05 14:11:34 TD Ameritrade | Logging in. (Step 1 of 3) | 2015-03-05 14:11:34 TD Ameritrade | Authorized for streamer data. | 2015-03-05 14:11:35 TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2015-03-05 14:11:35 TD Ameritrade | Requesting message key for account activity streamer (Step 3 of 3) | 2015-03-05 14:11:35 TD Ameritrade | Requesting account balance data. Connection will be complete once received. | 2015-03-05 14:11:35 TD Ameritrade | Connected. | 2015-03-05 14:11:35 Notice: The study 'Tilt' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:13 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:13 Notice: The study 'Tilt' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:13 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:13 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:13 Notice: The study 'Tilt' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:13 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:13 Notice: The study 'Tilt' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:13 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:13 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:13 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:14 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:14 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:14 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:14 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:14 Notice: The study 'OFE_OA' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2015-03-05 14:12:14 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\[TFH5.scid | 2015-03-05 14:12:14 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\[TFM1.scid | 2015-03-05 14:12:14 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TF FMH0015!-NYBOT.scid | 2015-03-05 14:12:14 Mapping /NQH5 to NQH15. Service code: cme | 2015-03-05 14:12:14 SC Exchange Data | Starting real-time market data updates for: NQH15. ID: 1 | 2015-03-05 14:12:14 Using username 0 | 2015-03-05 14:12:14 SC Exchange Data | Connecting to the server scdf2.sierracharts.com. Port 443 | 2015-03-05 14:12:14 Intraday data recording state for symbol /NQH5 is set to download pending. | 2015-03-05 14:12:14 HD Request # 2 | Downloading Intraday chart data for /NQH5 to the file [NQH5.scid. Service: cme | 2015-03-05 14:12:14 HD Request # 2 | Download start Date-Time: 2015-03-05 14:11:10.0 | 2015-03-05 14:12:14 HD Request # 2 | Using server: scdf2.sierracharts.com port 10149 | 2015-03-05 14:12:14 TD Ameritrade | Starting real-time market data updates for: /TFH5. ID: 2 | 2015-03-05 14:12:14 Intraday data recording state for symbol /TFH5 is set to download pending. | 2015-03-05 14:12:14 HD Request # 3 | Downloading Intraday chart data for /TFH5 to the file [TFH5.scid. Service: tda | 2015-03-05 14:12:14 HD Request # 3 | Download start Date-Time: 2014-08-31 15:12:14.0 | 2015-03-05 14:12:14 HD Request # 3 | Requesting 186 days of historical Minute data. | 2015-03-05 14:12:14 Mapping /ESH5 to ESH15. Service code: cme | 2015-03-05 14:12:14 SC Exchange Data | Starting real-time market data updates for: ESH15. ID: 3 | 2015-03-05 14:12:14 Intraday data recording state for symbol /ESH5 is set to download pending. | 2015-03-05 14:12:14 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-03-05 14:12:14 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-03-05 14:12:14 Mapping /YMH5 to YMH15. Service code: cbot | 2015-03-05 14:12:14 SC Exchange Data | Starting real-time market data updates for: YMH15. ID: 4 | 2015-03-05 14:12:14 Intraday data recording state for symbol /YMH5 is set to download pending. | 2015-03-05 14:12:14 Socket (2) | Connected. | 2015-03-05 14:12:14 HD Request # 2 | Sending historical data logon request message. | 2015-03-05 14:12:14 Socket (3) | Connected. | 2015-03-05 14:12:14 SC Exchange Data | Connected to server. | 2015-03-05 14:12:14 SC Exchange Data | Sending logon request message. | 2015-03-05 14:12:14 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2015-03-05 14:11:10. Record interval: 0. Symbol: NQH15 | 2015-03-05 14:12:14 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-03-05 14:12:14 SC Exchange Data | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-03-05 14:12:14 SC Exchange Data | Successfully connected. | 2015-03-05 14:12:14 SC Exchange Data | Restarting real-time data updates for symbol: /ESH5 -> ESH15 | 2015-03-05 14:12:14 SC Exchange Data | Restarting real-time data updates for symbol: /NQH5 -> NQH15 | 2015-03-05 14:12:14 SC Exchange Data | Restarting real-time data updates for symbol: /YMH5 -> YMH15 | 2015-03-05 14:12:14 HD Request # 2 | Decompressing data. | 2015-03-05 14:12:14 HD Request # 2 | Receiving Intraday data for /NQH5 starting at 2015-03-05 14:11:10 | 2015-03-05 14:12:14 HD Request # 2 | Timestamp of first Intraday data file record written: 2015-03-05 14:11:13 | 2015-03-05 14:12:14 Socket (2) | Shutdown and closed. | 2015-03-05 14:12:14 The network socket for historical data has been closed. | 2015-03-05 14:12:14 HD Request # 2 | Received 107 records from 2015-03-05 14:11:10 to 2015-03-05 14:12:08 (58.0 seconds) and wrote 106 records for /NQH5 | 2015-03-05 14:12:14 HD Request # 2 | Intraday download COMPLETE for /NQH5. Completion time: 0s. Unique request ID: 1 | 2015-03-05 14:12:14 Removed historical data download ID 1 | 2015-03-05 14:12:14 Real-time Intraday chart data file updates started for /NQH5 | 2015-03-05 14:12:14 HD Request # 4 | Downloading Intraday chart data for /ESH5 to the file [ESH5.scid. Service: cme | 2015-03-05 14:12:14 HD Request # 4 | Download start Date-Time: 2015-03-05 14:11:11.0 | 2015-03-05 14:12:14 HD Request # 4 | Using server: scdf1.sierracharts.com port 10149 | 2015-03-05 14:12:14 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-03-05 14:12:14 HD Request # 3 | Error downloading historical Intraday data for /TFH5. Data acquisition failed for 1 of 1 requests.Error retrieving data. | 2015-03-05 14:12:14 * HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for /TFH5 | 2015-03-05 14:12:14 HD Request # 3 | Intraday download COMPLETE for /TFH5. Completion time: 0s. Unique request ID: 2 | 2015-03-05 14:12:14 Removed historical data download ID 2 | 2015-03-05 14:12:14 Real-time Intraday chart data file updates started for /TFH5 | 2015-03-05 14:12:14 Socket (4) | Connected. | 2015-03-05 14:12:14 HD Request # 4 | Sending historical data logon request message. | 2015-03-05 14:12:14 TD Ameritrade | Starting real-time market data updates for: /TFM1. ID: 5 | 2015-03-05 14:12:14 Intraday data recording state for symbol /TFM1 is set to download pending. | 2015-03-05 14:12:14 HD Request # 5 | Downloading Intraday chart data for /TFM1 to the file [TFM1.scid. Service: tda | 2015-03-05 14:12:14 HD Request # 5 | Download start Date-Time: 2014-08-31 15:12:14.0 | 2015-03-05 14:12:14 HD Request # 5 | Requesting 186 days of historical Minute data. | 2015-03-05 14:12:14 TD Ameritrade | Starting real-time market data updates for: TF FMH0015!-NYBOT. ID: 6 | 2015-03-05 14:12:14 Intraday data recording state for symbol TF FMH0015!-NYBOT is set to download pending. | 2015-03-05 14:12:14 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-03-05 14:11:11. Record interval: 0. Symbol: ESH15 | 2015-03-05 14:12:14 HD Request # 4 | Decompressing data. | 2015-03-05 14:12:14 HD Request # 4 | Receiving Intraday data for /ESH5 starting at 2015-03-05 14:11:11 | 2015-03-05 14:12:14 HD Request # 4 | Timestamp of first Intraday data file record written: 2015-03-05 14:11:13 | 2015-03-05 14:12:14 Socket (4) | Shutdown and closed. | 2015-03-05 14:12:14 The network socket for historical data has been closed. | 2015-03-05 14:12:14 HD Request # 4 | Received 204 records from 2015-03-05 14:11:11 to 2015-03-05 14:12:09 (58.0 seconds) and wrote 201 records for /ESH5 | 2015-03-05 14:12:14 HD Request # 4 | Intraday download COMPLETE for /ESH5. Completion time: 0s. Unique request ID: 3 | 2015-03-05 14:12:14 Removed historical data download ID 3 | 2015-03-05 14:12:14 Real-time Intraday chart data file updates started for /ESH5 | 2015-03-05 14:12:15 HD Request # 5 | Error downloading historical Intraday data for /TFM1. Data acquisition failed for 1 of 1 requests.Error retrieving data. | 2015-03-05 14:12:15 * HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for /TFM1 | 2015-03-05 14:12:15 HD Request # 5 | Intraday download COMPLETE for /TFM1. Completion time: 1s. Unique request ID: 5 | 2015-03-05 14:12:15 Removed historical data download ID 5 | 2015-03-05 14:12:15 Real-time Intraday chart data file updates started for /TFM1 | 2015-03-05 14:12:15 HD Request # 6 | Downloading Intraday chart data for /YMH5 to the file [YMH5.scid. Service: cbot | 2015-03-05 14:12:15 HD Request # 6 | Download start Date-Time: 2015-03-05 14:11:03.0 | 2015-03-05 14:12:15 HD Request # 6 | Using server: scdf2.sierracharts.com port 10149 | 2015-03-05 14:12:15 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-03-05 14:12:15 HD Request # 7 | Downloading Intraday chart data for TF FMH0015!-NYBOT to the file TF FMH0015!-NYBOT.scid. Service: tda | 2015-03-05 14:12:15 HD Request # 7 | Download start Date-Time: 2014-08-31 15:12:15.0 | 2015-03-05 14:12:15 HD Request # 7 | Requesting 186 days of historical Minute data. | 2015-03-05 14:12:15 Socket (5) | Connected. | 2015-03-05 14:12:15 HD Request # 6 | Sending historical data logon request message. | 2015-03-05 14:12:15 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2015-03-05 14:11:03. Record interval: 0. Symbol: YMH15 | 2015-03-05 14:12:15 HD Request # 6 | Decompressing data. | 2015-03-05 14:12:15 HD Request # 6 | Receiving Intraday data for /YMH5 starting at 2015-03-05 14:11:03 | 2015-03-05 14:12:15 HD Request # 6 | Timestamp of first Intraday data file record written: 2015-03-05 14:11:14 | 2015-03-05 14:12:15 Socket (5) | Shutdown and closed. | 2015-03-05 14:12:15 The network socket for historical data has been closed. | 2015-03-05 14:12:15 HD Request # 6 | Received 78 records from 2015-03-05 14:11:03 to 2015-03-05 14:12:08 (65.0 seconds) and wrote 67 records for /YMH5 | 2015-03-05 14:12:15 HD Request # 6 | Intraday download COMPLETE for /YMH5. Completion time: 0s. Unique request ID: 4 | 2015-03-05 14:12:15 Removed historical data download ID 4 | 2015-03-05 14:12:15 Real-time Intraday chart data file updates started for /YMH5 | 2015-03-05 14:12:15 HD Request # 7 | Error downloading historical Intraday data for TF FMH0015!-NYBOT. Validation failed for 1 of 2 requests.Your request is not valid. | 2015-03-05 14:12:15 * HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMH0015!-NYBOT | 2015-03-05 14:12:15 HD Request # 7 | Intraday download COMPLETE for TF FMH0015!-NYBOT. Completion time: 0s. Unique request ID: 6 | 2015-03-05 14:12:15 Removed historical data download ID 6 | 2015-03-05 14:12:15 Real-time Intraday chart data file updates started for TF FMH0015!-NYBOT | 2015-03-05 14:12:15 TD Ameritrade | Streamer request #11 sent. | 2015-03-05 14:12:15 TD Ameritrade | Streamer response: NOT_AUTHORIZED_FOR_QUOTE. Additional text: Not authorized for all quotes. | 2015-03-05 14:12:16 TD Ameritrade | Streamer response: NOT_AUTHORIZED_FOR_QUOTE. Additional text: Not authorized for all quotes. | 2015-03-05 14:12:16 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 02-1 | 2015-03-05 14:12:16 |
| [2015-03-05 19:28:36] |
The /TFH5 symbol is on the ICE exchange. Your Sierra Chart account has this exchange enabled only: Enabled for: CME, CBOT, NYMEX, COMEX exchanges for trading accounts. | 2015-03-05 14:11:28 The problem is the ICE exchange fee is about 95 USD a month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-05 19:31:10
| [2015-03-06 15:10:39] |
So if I am getting a live quote for free on ameritrade for the russel mini what can't it just transfer over to Sierra Charts? Why would I have to pay for it when I get it for free?
| [2015-03-06 17:55:36] |
We wish you could. But the ICE market data rules have to be followed. For further information contact ICE and/or TD Ameritrade. Although contacting them will be of little practical help.
