Date/Time: Sun, 22 Dec 2024 17:47:19 +0000
is the creation of a move-stop-to-break-even button (with a pre defined tick offset) possible?
View Count: 1749
[2015-03-05 13:55:38] |
User63439 - Posts: 83 |
think the title says it all. thanks in advance Date Time Of Last Edit: 2015-03-05 13:58:35
[2015-03-05 17:16:35] |
ktfroy - Posts: 85 |
It would be nice.
[2015-03-05 18:25:06] |
Yes, we can do that and we will keep it in mind.
[2015-05-11 00:58:30] |
User52989 - Posts: 42 |
+1 Yes please - has been requested for some time - would mean not having to manually adjust stop.
[2015-05-12 03:39:01] |
We will try to get this done soon.
[2015-05-15 10:18:04] |
A move to breakeven button has been added in the latest release: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1255 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-15 11:42:56] |
User11942 - Posts: 298 |
It's great! But how to add this button in compact TradeDOM mode?
[2015-05-15 13:06:55] |
Thanks for adding that feature, but I can't find it - updated to 1255, can't see the function button for chart trade either within the chart trade settings box or TRADE -> CHART TRADE SETTINGS. What am I missing?
[2015-05-15 13:15:10] |
@User52989 It's on the Main Tab in TradeDOM. See screenshot attached. Date Time Of Last Edit: 2015-05-15 19:08:55
[2015-05-15 13:23:57] |
So it's not going to be implemented as part of Chart Trade? Transact (Infinity Futures) are unable to use TradeDOM.
[2015-05-15 13:28:03] |
It's also available on trade window which can be attached to a chart. Have no idea about Transact version though.
Date Time Of Last Edit: 2015-05-15 13:33:42
