Date/Time: Fri, 22 Nov 2024 19:05:02 +0000
Rosenthal Collins Group / TT
View Count: 1695
[2013-05-28 12:11:04] |
T44 - Posts: 363 |
Any plans to add support for Sierra Chart to accounts clearing RCG? Is there anything special the FCM needs to do to support Sierra on an existing TT environment?
[2013-05-28 16:44:29] |
If RCG uses one of the backend trading platform supported by Sierra Chart, then Sierra Chart can be used with them. Refer to this page: https://www.sierrachart.com/index.php?l=doc/data.php Sierra Chart does work with a TT FIX adapter. So if they have a TT FIX adapter , then Sierra Chart can be used with them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
