Date/Time: Wed, 09 Sep 2026 05:07:12 +0000
[User Discussion] - Key reversal bar using Colour bar based on alert condition (or similar)
View Count: 2185
[2015-03-04 18:08:41]
User96105 - Posts: 113
Can anyone help with the correct code for this please? I want to show a bar colour change (or an arrow etc) to show key reversal bars ~ where in a downtrend the low is lower than the previous bar, but the close is within the top half of the bar (and conversely up bars).
Many thanks.
[2015-03-04 21:46:28]
Sawtooth - Posts: 4351
Try this:
=AND(L<L[-1],C>(H-L)/2)
[2015-03-05 11:12:27]
Great, thanks Tom, you set me on the right track. This seems to work for a close in the top/bottom 1/3rd of the bar:-
=AND(L<L[-1],C>(H-(H-L)/3)) for a bottom reversal and
=AND(H>H[-1],C<(L+(H-L)/3)) for top reverse
[2020-10-16 14:55:48]
User616224 - Posts: 6
Hi, I would like to have Key Reversal indicator, but I can't program, so I don't know where should I put that code. Don't you please have the *.cpp file of it?
[2020-10-16 15:18:04]
Add two instances of the Color Bar Based On Alert Condition study, and put each formula in post#3 on the respective Alerts tab of each.
[2020-10-16 16:01:22]
I got it. Works beautifully. Thank you!
