Date/Time: Sat, 21 Dec 2024 17:47:40 +0000
"Rogue" Trade Window
View Count: 902
[2015-03-03 18:44:03] |
User68474 - Posts: 201 |
I have a rogue trade window that I cannot seem to remove. The top of the window has migrated out of sight above my monitor' uppermost display level, therefore, I can neither grab and drag it back down, nor can I read which determine with which chart is it associated/attached. I have tried "Window/Restore All Trade Windows" to no avail. It blocks the chart on top of which it "resides". Help, please!
[2015-03-03 18:55:44] |
Try to determine what chart or Trade DOM it is associated with and then go to that chart and select Chart >> Reset Child Windows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
