Date/Time: Tue, 06 Oct 2026 10:11:16 +0000
drawing support
View Count: 1252
[2015-03-03 11:12:34]
navigator - Posts: 27
When I draw parallel lines I have all the options checked, enable vertical lines, mark anchors, extend forward, allow horizontal shift. This will show me the dots that I have to connect with a ray or line to draw the midline of the parallel lines. Unfortunately when I switch tools from parallel rays to a line or ray to draw the midline, the dots will disappear. I need those dots to remain while I switch tools. How is that done? Or is there another way of drawing the midline between parallel lines. Thanks
[2015-03-03 17:44:22]
If you want a midline between the parallel lines, you need to add a 50% Level to the Parallel Lines configuration:
Chart Drawing Tools: Drawing Tool Configuration
Refer specifically to the Parallel Lines subsection in this section.
Date Time Of Last Edit: 2015-03-03 17:44:41
