Date/Time: Mon, 16 Sep 2024 19:13:57 +0000
Looking to create a dom chart.
View Count: 902
[2015-03-03 00:23:18] |
User48557 - Posts: 138 |
A fellow Sierra chart user publicly posted a image of this chart. How do i replicate such a chart?
Capture dom.GIF / V - Attached On 2015-03-03 00:22:29 UTC - Size: 125.65 KB - 412 views |
[2015-03-03 17:06:14] |
I don't need the help anymore.I found out how. I had to go to ''find symbol'' Then i selected, '' Open Trading Dom'' .
[2015-03-03 17:27:08] |
Nevertheless, this is the relevant documentation: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#TradeDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
