Date/Time: Sat, 21 Dec 2024 16:14:14 +0000
Chart showing as remote instance when it is not - wont allow redownloading
View Count: 886
[2015-03-02 22:59:02]
rhovega - Posts: 279
Have a chartbook which I usually open on a remote instance. I need to redownload data, so I opened it on the main instance. Even though the chart/symbol shows "this instance" as the source, SC is recognizing the chart as a remote instance (showing the R).
Thus it won't allow to delete and download data. I need to redownload.
Please help.
Thanks.
[2015-03-04 04:18:37]
What you need to do in this case is select Chart >> Chart Settings. Beside the symbol box press the Find button . Make sure at the top it is set to This Instance and reselect the symbol.
