Date/Time: Mon, 16 Sep 2024 19:09:26 +0000
error code 60
View Count: 1153
[2015-03-02 21:00:07] |
User27605 - Posts: 9 |
I'm getting error code 60; I checked the support board and changed my port to 1869 without any luck. What should I try next? Thank you.
[2015-03-02 22:23:13] |
This is an error code from the TransAct system. If you are getting error code 60 then it does indicate that the local port number is correct. Please contact TransAct support for help with this: http://www.transactfutures.com/ContactUs.htm Let them know you are getting error code 60 when connecting to TransAct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
