Date/Time: Sat, 21 Dec 2024 17:51:01 +0000
td ameritade
View Count: 1006
[2015-03-02 19:54:30] |
User33988 - Posts: 6 |
When I try to use the sierra chert trading dom with my ameritrade account I get a message saying invalid symbol. How do I corrcet this? Thank You; David |
[2015-03-02 19:58:52] |
What is the symbol you are trading?
[2015-03-02 20:07:03] |
/esh5
[2015-03-02 20:31:56] |
The interface Sierra Chart has to TD Ameritrade does not support trading futures.
[2015-03-02 20:32:46] |
ok thank you
