Date/Time: Wed, 16 Sep 2026 23:43:08 +0000
Add custom Study, freeze
View Count: 1408
| [2015-03-02 18:28:50] |
| User025842 - Posts: 13 |
HI ! After downloading new ver.1237,going to "add custom study", the stud is added ,working fine. But when you click again on "add custom study" ,the whole program freezes and stop working, is it something known to you,or it is on my end something wrong? Thank you for you time |
| [2015-03-02 18:32:42] |
Refer to help topic 17.3 here about this: https://www.sierrachart.com/index.php?page=doc/helpdetails17.html#h17.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
