Date/Time: Mon, 16 Sep 2024 19:17:43 +0000
NinjaTraderBrokerage
View Count: 775
[2015-03-02 15:56:53] |
User80386 - Posts: 9 |
Can I connect with SierraChart to my account in NinjaTraderBrokerage throughout the datafeed Continium?
[2015-03-02 18:16:55] |
Yes. Continuum is the same as CQG. Follow the instructions here: CQG Trading Platform Service: Setup Instructions However, make sure your CQG account is set to use the CQG FIX server. Or select "CQG Web API" as the Service in Sierra Chart instead of CQG FIX Trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
