Date/Time: Mon, 21 Sep 2026 02:46:17 +0000
Linking
View Count: 1154
| [2015-03-02 13:52:18] |
| User27109 - Posts: 21 |
is there a way to link charts together of the ES so I don't have to draw the same lines on each chart. Right now I have all charts linked by symbol and assigned to 1 but it doesn't appear that the drawing I make on the 405m chart link to the other time frame charts. |
| [2015-03-02 16:15:42] |
You will need to use the Copy Chart Drawings from Chart #'s setting under Chart >> Chart Settings as is documented here: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support |
