Date/Time: Sat, 21 Dec 2024 17:54:55 +0000
chart update fails with IB connection
View Count: 897
[2015-03-02 08:46:50]
User94740 - Posts: 333
I have sent a copy of the log already and hopefully you can help
[2015-03-02 09:02:18]
hi SC, they are updating now, but there is a lag between the IB platform and SC charting software
[2015-03-02 09:08:48]
SC, my oil charts are updating with lag, but gold fails to update
[2015-03-02 09:13:13]
ps: copper seems to be working fine
[2015-03-02 10:54:27]
hi SC, after rebooting and closing and reopening multiple times, it seems everything is working.
[2015-03-02 17:16:01]
We did not look at the Message Log since you said the problem is resolved, but most likely the problem you are describing is the result of a long time to download historical data from Interactive Brokers. Refer to:
https://www.sierrachart.com/index.php?page=doc/IB.php#SlowDownloading
For a problem with lagging data, refer to help topic 4:
Http://www.sierrachart.com/index.php?page=doc/helpdetails4.html
