Date/Time: Thu, 16 Jan 2025 04:41:27 +0000
Why Are TPO Profile Charts and TPO Value Area Lines So Different?
View Count: 3369
[2015-03-01 18:33:54]
cmet - Posts: 580
Hopefully someone can help me figure this out.
What I have is this:
1. 1 Min Chart of ES, Day Session only
2. Standard TPO Profile (30min blocks, 70% value area, etc)
3. TPO Value Area Lines. These are set to the same 30min and 70% value area and are set to plot the value area and POC from the previous day onto the current day.
However, when I do this, the levels are completely off.
Here is an annotated image of the chart and the settings. The TPO Value Area Lines are the grey boxes with the pink POC.
http://s7.postimg.org/w0nkydg0r/TPODifferences.jpg
They should line up with the previous day's value area and POC. Sometimes some of them are close but they should be exact.
I've checked/tried everything here: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#IncorrectValues and it my settings look correct for getting accurate results.
What might cause this?
Date Time Of Last Edit: 2015-03-01 20:08:53
[2015-03-01 20:08:11]
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#UsingOtherStudies
[2015-03-01 20:31:41]
cmet - Posts: 580
Okay, so the solution is simply this:
1. Plot TPO Value Area Lines onto a 1 Minute chart (or any time frame that is an increment of 30 - 2,3,5,6,10,15).
2. Use Study/Price Overlay to then add it to any other chart you want.
The levels plot accurately this way.
Date Time Of Last Edit: 2015-03-01 20:40:21
[2017-10-12 19:27:24]
User459170 - Posts: 262
Why are the following two studies on the same chart giving completely different Value area lines?
a) TPO Profile Chart
b) TPO Value Area Lines
I have gone through the above link, but that doesnt explain the difference.
[2017-10-12 21:01:08]
The reason is explained here:
Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart (Using Other Studies on a TPO Chart)
TPO Value Area Lines is not a study which can be used on a TPO Profile Chart. It is not listed in the section linked to.
Date Time Of Last Edit: 2017-10-12 21:01:25
