Date/Time: Sat, 21 Dec 2024 17:49:47 +0000
Feature Modification: Additional slots for price expansion
View Count: 940
[2015-02-28 10:27:23] |
U.Sohyur - Posts: 21 |
Is it possible to add additional slots to the price expansion tool? Currently there are 31 possible expansion values + the tool. Could it be made to 50 or so? If it's as easy as just changing a number in the code, then maybe 100 values? That should definitely be enough. This would help me significantly. Thanks much. |
[2015-02-28 13:52:42] |
No, it is not easy for us to expand this.
