Date/Time: Sat, 21 Dec 2024 17:19:04 +0000
TickByTickData_sierra_data_feed
View Count: 1279
[2015-02-28 08:15:17] |
User45317 - Posts: 18 |
Hi, I want to buy package 5 and sierra data feed with tick by tick data. Where I can buy this data feed? |
[2015-02-28 13:53:41] |
Instructions for activating and paying for the Sierra Chart Exchange Data Feed are here: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-03 20:48:47] |
THX. What I have to buy when I need tick by tick data for e mini futures (ES,YM,NQ,EMD...) and I need tick by tick for ETFs (SPY,SPX,RUT,IWM,QQQ...) How long is history for tick by tick?
[2015-03-03 21:26:47] |
Do you have a futures trading account? For futures, there is at least 3 years of tick by tick data. For stocks and ETFs, it is about six months. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-03 11:18:01] |
Which package I need for markets e mini ES, YM, NQ, EMD and ETFs SPY,SPX,RUT, IWM,QQQ THX
[2015-04-06 19:10:16] |
Do you have a funded futures trading account? And do you require real-time data for these markets? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-07 16:52:52] |
I have funded trading account (interactive brokers). I have datafeed from IB, but these markets are snapshot. I need stream tick by tick for these markets. Where I can do add these market?
[2015-04-07 17:14:11] |
You can use any Sierra Chart service package. For historical and real-time data for ES, YM, NQ, EMD and ETFs SPY,SPX,RUT, IWM,QQQ THX, you need to use the Sierra Chart Real-time and Historical Exchange Data Feed which is documented here: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-07 19:20:06] |
Thank you. I actived data. I must active exactly exchange? How is historical data when I have active this? tick by tick?
[2015-04-07 20:14:37] |
You need the CME Group exchange for 3.25 USD per month. And either the US Equities exchange or the BATS exchange for the ETFs. For historical tick by tick data, for the futures you will get at least 3 years and for the stocks it would be at least 6 months. For BATS though the amount of historical tick by tick data is only going to be about a month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-07 20:34:05] |
THX. I got it. and what ebou back adjusted data for continual contract monhts?
[2015-04-07 20:47:18] |
This is supported. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-08 16:36:41] |
THX. I am going to connect SC Exchange data but data is not real stream. Why? I doing everything.
[2015-04-08 16:56:25] |
You must connect to your Interactive Brokers account and use the Interactive Broker symbols as explained here: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration It is necessary because of what is documented here: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-08 16:56:52
