Date/Time: Mon, 16 Sep 2024 20:00:53 +0000
Symbol changes unexpectedly
View Count: 919
[2015-02-27 16:37:12] |
User63769 - Posts: 35 |
When I switch to 1 hour bar periods, the symbol in the window switches unexpectedly to a previous symbol
[2015-02-27 16:38:09] |
Are you using chart linking and linking by symbol?: http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChartLinking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-27 16:47:13] |
No I am not using chart linking
Symbol changes unexpectedly.PNG / V - Attached On 2015-02-27 16:47:09 UTC - Size: 162.3 KB - 325 views |
[2015-02-27 16:49:36] |
What symbol is it switching from and to?
[2015-02-27 16:55:55] |
It is switching from USD.CAD to AAPL, although it does this from all of my windows. Perhaps I am using a keyboard shortcut that doesn't exist: I have been typing "1h". |
[2015-03-03 06:50:22] |
This is not a valid short cut. You would have to type 60m instead.
