Date/Time: Fri, 25 Sep 2026 00:50:35 +0000
Submit 2 orders through ACSIL
View Count: 1290
| [2015-02-27 10:36:00] |
| crazybears - Posts: 314 |
Hi Sierra Chart Engineering I desperately need your help through custom strategy , when bar has closed ,I'd send 2 orders at different prices with different target and stop. please , Can you provide an example of as i have to do it , i read instructions on web page and in trading system example but so far i'm not able to find a solution . kind regards thanks |
| [2015-02-27 16:43:15] |
Have you already written the code that submits 2 orders? What is the problem that you are encountering? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-02-28 23:51:35] |
Hi Sierra Chart Engineering sorry for the late , i checked the the code again and again and found i made stupid mistake ,setting sc.Maximum Position Allowed = 1 orders are correctly sent and executed. instead to have orders joined in the average price of execution , can be displayed each single order at its price of entry? thanks |
| [2015-03-03 06:51:06] |
No, this is not supported.
