Date/Time: Sun, 08 Sep 2024 00:06:50 +0000
2 charts in one window
View Count: 2486
[2015-02-27 01:34:05] |
User86204 - Posts: 3 |
Hello I’m trying to use 2 charts in one window to help me with my trading, similar to the attached image. I’m thinking about the trading Chart DOM and Numbers bars on one chart and a 3 minutes candlestick bars on the other. I want both of them to be on the same chart window so I will have one tab for every instrument I’m trading. Is it possible? |
[2015-02-27 22:39:21] |
Yes this is possible. Refer to this section here: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#SelectingCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-27 22:42:40
[2015-03-01 23:21:52] |
Hello, thank you for your reply. However, the linked document explains how to add tabs to a chartbook and not how to place 2 graphs on the same chart. Thank you Ofer |
[2015-03-02 17:27:33] |
Therefore, use the Overlay (Bar) study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s100 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
