Date/Time: Sat, 21 Dec 2024 17:46:41 +0000
How do i view historical data that is pre 1900
View Count: 1008
[2015-02-26 01:05:07]
User838227 - Posts: 4
I am wondering how I would go about viewing a chart of daily stock data that is pre 1900. I was able to do this in a previous version of Sierra Charts, I just recently re-enabled my account and installed the latest version of Sierra Chart and i cannot do it any longer. For example i have daily data of the Dow Jones Average, from 1885 to 2015, and when i try opening up the file, only data from January 1, 1900 to todays date is displayed. What do i have to do to correct this, and have all my data displayed.
[2015-02-26 01:41:04]
Are the years in a four digit format?
[2015-02-26 04:02:08]
We have looked into this, and apparently what happens is that dates earlier than 1900 are filtered out because they have a negative value internally.
Therefore, this is not supported.
Let us know if you would like a refund.
It is not worth it for us to support this because it involves too much changes and analysis.
[2015-02-26 23:41:47]
Oh ok. But I had no problem viewing pre-1900 data on an older version of Sierra Charts (a version from last year). Is it possible to uninstall the current version of Sierra Charts and re-install my older version that allowed viewing older data?
[2015-02-27 00:04:35]
Yes. You can find older versions here:
https://www.sierrachart.com/index.php?page=doc/SCInstallerList.php
[2015-02-27 00:09:14]
Yes, i had a Sierra Chart version from January of 2014 on my hard drive (as a back-up). I installed it on my computer and it allows me to plot stock data from prior to january 1, 1900. So that problem is solved using an older version.
