Date/Time: Sat, 21 Dec 2024 17:42:03 +0000
reset to pointer or crosshairs when using studies?
View Count: 1528
[2015-02-25 15:14:03] |
User60518 - Posts: 106 |
Hi - not sure if it's possible or already a feature but Is it possible to have the cursor reset to either pointer or crosshair after a tool is drawn? for example- I select the tool 'Draw Volume Profile' or 'Price Retracement Tool' - is it possible that after I have used these tools the cursor resets to 'pointer' or crosshairs so I don't unwittingly draw additional unwanted tools on my charts? not essential but a nice to have........... Thanks! Date Time Of Last Edit: 2015-02-25 15:15:16
[2015-02-25 15:38:23] |
Sierra Chart - Max - Posts: 5756 |
Refer to After Single Tool Use Change To here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#GeneralToolOptionSettings Sierra Chart Support |
[2015-02-25 22:48:59] |
Thanks!
[2015-02-25 22:53:17] |
There is no need to say thank you please. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
