Date/Time: Thu, 02 Jul 2026 12:28:21 +0000
Candlestick formations
View Count: 1095
| [2015-02-24 16:51:28] |
| User32803 - Posts: 18 |
Is there a way to have the candlestick bodies red for a down fill and green for an up fill with all shadows above and below the bodies say, grey for each candle.
| [2015-02-24 19:45:13] |
Yes. Refer to the General Settings >> Graphics Settings documentation here about the specific color settings you can use to control this: Graphics Settings: Colors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
