Date/Time: Sun, 22 Dec 2024 05:41:49 +0000
Simple indicator
View Count: 858
[2015-02-24 16:34:08] |
User38993 - Posts: 61 |
I would like to make a simple indicator. Basically it shows Bollingerband Upper line value - Bollingerband mid line value = X I want X to show as indicator. Would this be possible? |
[2015-02-24 18:33:56] |
Yes. Use the Study Subgraphs Difference study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s185 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
