Date/Time: Sun, 22 Dec 2024 05:03:09 +0000
can't see a lot of history back using Interaxtive broker as data feed
View Count: 884
[2015-02-24 16:04:28] |
User67344 - Posts: 7 |
the ESH15.dly is very small file. I can't see an history of few years -only 6 quarters . what can be the reason- I am using IB as a source? Regards, Areil |
historical data -ES.jpg / V - Attached On 2015-02-24 16:04:12 UTC - Size: 167.14 KB - 421 views es-querterly.jpg / V - Attached On 2015-02-24 16:04:24 UTC - Size: 53.96 KB - 370 views |
[2015-02-24 18:04:03] |
Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
