Date/Time: Sun, 22 Dec 2024 05:21:55 +0000
Can you mark a trendlines value on scale?
View Count: 878
[2015-02-24 12:57:12] |
Adam - Posts: 141 |
hi see attached image you will see the trnedline on CQG has a value of 50.31 is there a way of doing this on SC so i can see the exact value a trendline marks?
ghgfhgfh.png / V - Attached On 2015-02-24 12:56:59 UTC - Size: 58.76 KB - 339 views |
[2015-02-24 18:21:47] |
No, this is not supported.
[2015-02-24 23:44:54] |
Adam - Posts: 141 |
Any chance of adding it to a release?
