Date/Time: Sun, 22 Dec 2024 05:52:21 +0000
[User Discussion] - Cum Delta divergence
View Count: 1090
[2015-02-24 08:01:52] |
User41512 - Posts: 58 |
Hi, I didn't get a reply to my earlier mail, so i have resent it (below): This tool seems to work ok when I use an intraday chart, but when I try to use with a historical chart, the cumulative Delta bar reading turns into a flat line. Please advise Thks |
[2015-02-24 08:13:58] |
This question is not within the scope of our support.
