Date/Time: Sun, 22 Dec 2024 05:25:28 +0000
Examples of code for sc.GetTradePositon
View Count: 814
[2015-02-24 02:21:24] |
CMG - Posts: 179 |
Hi, Do you have examples of code that uses the following: sc.GetTradePosition and or with s_SCPositionData Structure Members I have not been able to find one.. Thaks |
[2015-02-24 02:55:19] |
Yes. This is in /ACS_Source/TradingSystem.cpp file.
