Date/Time: Sun, 22 Dec 2024 05:10:14 +0000
ACSIL DRAWING_HORIZONTALLINE TEXT
View Count: 898
[2015-02-23 20:05:41] |
Trade Nice - Posts: 75 |
Is it correct that the font type and size cannot be set with ACSIL for the DRAWING_HORIZONTALLINE TEXT, and that the font and size can only be set globally in Global Settings>>Tool Settings and then Global Chart Drawing Font?
[2015-02-23 20:10:58] |
Yes. This is correct.
