Date/Time: Fri, 22 Nov 2024 19:05:36 +0000
update symbols in charts automatically: "If date between x and y
View Count: 1753
[2013-05-27 14:13:03] |
pkhst958 - Posts: 57 |
Hi all, is there a way to automatically update the sysmbols in the charts? I trade futures, which symbols I need to change 4 times a year. Can I do that automatically, entering a formulae "If date between x and y, then chart symbol:=z"? |
[2013-05-28 00:18:54] |
Yes. You need to use the Rollover settings for the symbol in the Global Settings >> Symbol Settings window: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-28 19:18:49] |
I cannot find it! Could you point me to it in sc menu? Global Settings >> Symbol Settings ; I choose ES-######-GLOBEX; - and then? Or as described in the link you had sent: chart settings >>> and then???? |
[2013-05-28 21:01:42] |
The version you are running might not have this. Please update. You need to go to Global Settings >> Symbol Settings, select the symbol and then select the Rollover tab. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
