Date/Time: Sun, 22 Dec 2024 05:28:27 +0000
[User Discussion] - Time interval
View Count: 867
[2015-02-22 19:58:36]
User47767 - Posts: 1
Hi SC,
I set some formulas based only on price movements (without using technical indicators) and I have got more signals then I expected (more then I could see on a chart and a Spreadsheet) in Activity Log. I have used tick data and 5 minutes chart.
That was probably because I used tick data and during 5 minutes interval signal appeared. Am I right? But when this interval was completely displayed (after 5 minutes), the signal should not be displayed.
I would need to implement some formula (as a part of complete formula) to give an order in order to display potential signals, for example, at last minute in 5 minutes bar (only during the last 1 minute in 5 minutes interval). For part of the complete formula but I need this fast tick movement...
Is there some appropriate solution?
Thanks for your advice.
