Date/Time: Mon, 28 Sep 2026 15:16:33 +0000
[User Discussion] - Color Bar Based On Alert Condition
View Count: 3026
[2015-02-22 15:34:11]
Kenneth.S - Posts: 20
I am trying to color a bar based on an alert condition and have added the study.
My chart consists of
Subgraph 1 - volume study
Subgraph 2 - Color Bar Based On Alert Condition
Subgraph 3 - Moving Average
if I in the color bar based... study uses alert condition = V > 1000 , i get the bar colored (as expected) when volume is larger than 1000.
If I use the condition = SG1 > 1000, i do not get the bar colored when volume is larger than 1000 (nothing is ever colored).
If I use the condition = SG3 > L, i would expect the bar to be colored if the value of the moving average is larger than the low of the bar, however that doesnt happen either.
I tried several other studies as subgraphs, it seems the color bar based on.... study doesn't color anything when I reference any subgraph in the alert.
The coloring works fine when I use any other alert condition, except referencing any subgraph.
I have tried this in version 1224 and also in the pre-release 1233.
[2015-02-22 21:18:10]
Sawtooth - Posts: 4355
You are confusing Subgraphs with Chart Regions. Subgraphs are separate outputs within a study.
Referencing V or L directly works because it is part of the OHLCVT data, but to reference the Volume study specifically, you need to use its ID#. The Studies to Graph list will show the ID# of each study. So from the Color Bar study, the syntax will look like this:
=ID1.SG1>1000
assuming the Volume study is ID1.
The same goes for the MA.
[2015-02-23 09:10:29]
Thanks...
[2015-02-23 09:18:20]
When using the Color Bar Based on Alert Condition study you cannot reference any Subgraphs within that study. This simply will not work.
You can only reference other studies or the main price graph. Refer to the documentation here:
http://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html#ReferencingOtherStudies
Date Time Of Last Edit: 2015-02-23 09:18:45
