Date/Time: Sun, 22 Dec 2024 05:27:43 +0000
[User Discussion] - Over executing
View Count: 970
[2015-02-21 01:04:09]
CustomIndicators - Posts: 126
I have an if statement that looks for a condition to be met, than executes a block of code intended to draw something on the chart. The if statement monitors already closed candles. When the test is true, I get a rush of all the same thing, when I only want it to do it once. I've set a part of the executed code block to add messages into the alerts, so I could see what was going on, and to see if the code block was executing in the first place. This is the result I got:
Chart: Replay 30.0X: AUDJPY 5 Sec #1 | Study: MyIndicator | Peak 1: 0.001690 | 2015-02-20 22:16:31
Chart: Replay 30.0X: AUDJPY 5 Sec #1 | Study: MyIndicator | Peak 1: 0.001690 | 2015-02-20 22:16:32
How can I fix it, and bring it down to just one entry per closed candle?
[2015-02-21 01:47:04]
Refer to:
http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#AllowOnlyOneTradePerBar
[2015-02-21 05:45:20]
Alright. That solves the automated trading part of this, but what about the processing? When a new bar closes, I'm getting that repeated execution. Is there a way to stop that as well, as to cut down on the processing?
