Date/Time: Sun, 22 Dec 2024 05:02:36 +0000
Filter trade size in Culmulative Delta.
View Count: 1255
[2015-02-21 00:07:44] |
Rino - Posts: 124 |
Hi, Thanks, I only want trades of 100 lots or more (>99) to show in my cumulative Delta. (Not affecting price) If I use the Volume Filter and specify >99 and leave the -Filter Trade Completely- unchecked, would that do it? http://www.sierrachart.com/image.php?l=1424476740598.png Date Time Of Last Edit: 2015-02-21 00:11:41
[2015-02-23 00:28:19] |
Rino - Posts: 124 |
Re-post in case missed, please. (Many post answer after this one was posted.) Thanks |
[2015-02-23 01:32:52] |
You need to use : Volume Filter >> Include <= 99 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
