Date/Time: Sat, 12 Sep 2026 16:03:58 +0000
[User Discussion] - Persistent Variables Through Functions for Drawing
View Count: 1455
[2015-02-20 23:14:12]
CustomIndicators - Posts: 126
I'm trying to make a function for drawing arrows that I can call, so I can have a bunch of other functions give it specific color/line number/type/position/markertype.
The function I've built so far is:
void DrawArrows(SCStudyGraphRef sc, unsigned int chartNumber, unsigned int id, SCDateTime positionDT, float value, unsigned int type, unsigned int color) {
s_UseTool Tool;
Tool.Clear(); // reset tool structure for our next use
Tool.ChartNumber = chartNumber;
Tool.DrawingType = DRAWING_MARKER;
Tool.LineNumber = id;
Tool.BeginDateTime = positionDT;
Tool.BeginValue = value;
Tool.Color = color;
Tool.AddMethod = UTAM_ADD_OR_ADJUST;
Tool.MarkerType = type;
Tool.MarkerSize = 10;
Tool.LineWidth = 2;
sc.UseTool(Tool);
And I call it with something like:
DrawArrows(sc, 1, sc.Index, peakOneDT, peakOne, MARKER_ARROWDOWN, COLOR_YELLOW);
I can't seem to figure out how to fix the error:
C:\SierraChart\ACS_Source\My_Indicator.cpp: In function 'void scsf_FRO(SCStudyInterfaceRef)':
C:\SierraChart\ACS_Source\My_Indicator.cpp:95:157: error: a function-definition is not allowed here before '{' token
C:\SierraChart\ACS_Source\My_Indicator.cpp:247:84: error: 'DrawArrows' was not declared in this scope
-- End of Build -- 16:00:37
I suspect that the problem may lye where I try to put through a persistent variable for the SCDateTime. I know that the persistent variable is working correctly, due to it working in other parts of my code.
Date Time Of Last Edit: 2015-04-04 05:39:08
