Date/Time: Wed, 30 Sep 2026 08:38:04 +0000
TPO Charts Plotting Wrong
View Count: 1596
| [2015-02-20 19:18:36] |
| User16114 - Posts: 153 |
Hi, opened my first TPO chart in a while and the plots in my ES TPO chart do not match my 30 minute ES chart. The low in the second 30 min bar (RTH) is 2082.25 and in the TPO chart the low is 2082.50. The TPO chart is different in a few other places as well. I've read through the documentation and can't find the issue. If I change the Chart Settings>>Advanced Settings 2>>Historical Price Multiplier from .01 to 1 I get the right prices on the chart but the TPO Letters turn to vertical lines. |
| [2015-02-20 19:35:22] |
Set the Letter/Block Price Increment in Ticks study Input to 1.
| [2015-02-20 22:16:44] |
Set to 1 prior to post #1. Is there anything else I can check?
| [2015-02-20 22:56:28] |
You said you set this to 1: Chart Settings>>Advanced Settings 2>>Historical Price Multiplier from .01 to 1 Letter/Block Price Increment in Ticks study Input is different. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-02-20 23:07:31] |
They were both set to 1. ************************************* ISSUE RESOLVED BY CREATING NEW CHART! ************************************* For anyone interested - Opened a new chart and added TPO Study and it is accurate. Checked all the settings against the chart that is not accurate and they are the same. Only difference I am aware of is the inaccurate chart was created by making a duplicate of a 30 min chart and adding TPO study after deleting all other studies. Thanks SC for your support. |
| [2015-02-21 01:01:03] |
Does not make sense to us. And we are also not completely clear on the problem either. Anyway, we will just let this go.
