Date/Time: Fri, 22 Nov 2024 18:49:49 +0000
Historic Intraday Ajax Data missing
View Count: 1714
[2013-05-27 07:57:19] |
User33881 - Posts: 2 |
Did not check all symbols, but all the symbols I did check, have Ajax Historic Intraday missing for May 19, 20, 21 and until 17:00CT on the 22nd? |
[2013-05-27 08:12:32] |
Please provide us a specific symbol. We are not seeing this missing data.
[2013-05-27 08:30:21] |
Ok, as you did not have problem, I did more checking, and my max download days value had changed and that was what was causing the problem. Reset it to its normal value and all good. Thank you and also for the speedy reply. |
