Date/Time: Sun, 13 Sep 2026 21:46:05 +0000
Problem : configurations simulation / non-simulation
View Count: 1250
| [2015-02-19 18:26:08] |
| User52247 - Posts: 26 |
In "Trade Window" I have a configuration with one stop and one target (attached orders). In simulation, with limit order, when I change entry on the chart, the target and the stop is modified. But in non-simulation, when I modify the entry, the target and the stop is not modified, Why? I have 1233 version, and my broker is OEC. Thank you for your answer ad101166 |
| [2015-02-19 18:38:15] |
To solve this disable Global Settings >> General Trade Settings >> Use Server-Side OCO and Bracket Orders.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-19 18:38:40
| [2015-02-24 18:55:26] |
Hello, My previous problem is resolved, but I have another problem : I have several strategy but they all show the same target and the same stop, even the strategy of Sierra originals, why? Thank you for your answer, ad101166 |
| [2015-02-24 19:07:36] |
Are you referring to Trade Window configurations: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
