Date/Time: Thu, 24 Sep 2026 01:43:51 +0000
Error Connecting--Windows Error Code 10061
View Count: 2961
[2015-02-18 14:56:39]
User22853 - Posts: 1
I cannot connect to the data feed. Everything worked fine yesterday and I made no changes since. I sent the Message log for analysis:
Software version: 1224 | 2015-02-18 09:52:21
Uses New Spreadsheets | 2015-02-18 09:52:21
Usage end date: 2015-08-08 | 2015-02-18 09:52:21
Enabled for: Advanced Features. | 2015-02-18 09:52:21
Enabled for: Advanced Features 2. | 2015-02-18 09:52:21
Enabled for: Sierra Chart Historical Data Service. | 2015-02-18 09:52:21
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-02-18 09:52:21
Active service: Rithmic Trading | 2015-02-18 09:52:21
Data/Trade Service Settings automatically set. | 2015-02-18 09:52:21
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-02-18 09:52:21
2015-02-18 08:52:21 Local computer clock time | 2015-02-18 09:52:21
2015-02-18 14:52:21 GMT time | 2015-02-18 09:52:21
2015-02-18 09:52:21 Time zone adjusted time | 2015-02-18 09:52:21
Time difference to server time: 0 seconds. | 2015-02-18 09:52:21
Program path: C:\SierraChart1\ | 2015-02-18 09:52:21
Data Files path: C:\SierraChart1\Data\ | 2015-02-18 09:52:21
OS Version Number: 6.2 | 2015-02-18 09:52:21
Locale Information: C | 2015-02-18 09:52:21
Checking for new symbol settings for rim | 2015-02-18 09:52:21
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-02-18 09:52:21
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-02-18 09:52:21
Symbol settings are up-to-date for rim | 2015-02-18 09:52:22
Files to Open on Start up | Opening file: Vermont Volume Traders CL.cht | 2015-02-18 09:52:24
Files to Open on Start up | Opening file: Vermont Volume Traders ES.cht | 2015-02-18 09:52:24
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-02-18 09:52:27
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-02-18 09:52:27
Rithmic Trading | Port for executable: 57668 | 2015-02-18 09:52:27
Listening socket (1848), port 57668 | Closed. | 2015-02-18 09:52:27
Rithmic Trading | Starting server: C:\SierraChart1\Rim\DTCBridge.exe | 2015-02-18 09:52:27
Chart #2 has tagged chart #1 for full recalculation. Chartbook: Vermont Volume Traders CL.cht | 2015-02-18 09:52:28
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Vermont Volume Traders CL.cht | 2015-02-18 09:52:29
Study/Price Overlay DateTime: Array is unallocated. | 2015-02-18 09:52:29 *
Study/Price Overlay DateTime: Array is unallocated. | 2015-02-18 09:52:30 *
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57668 | 2015-02-18 09:52:30
Socket (2) | Connected. | 2015-02-18 09:52:30
Rithmic Trading | Connected to server. | 2015-02-18 09:52:30
Rithmic Trading | Sending logon request message. | 2015-02-18 09:52:30
Rithmic Trading | Starting the connection process to data and trading service. | 2015-02-18 09:52:30
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart1\Rim\Rithmic.log | 2015-02-18 09:52:30
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-02-18 09:52:30
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-02-18 09:52:31
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-02-18 09:52:31
Rithmic Trading | Server Name: DTC Bridge. | 2015-02-18 09:52:31
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-02-18 09:52:31
Rithmic Trading | Logon error from server | 2015-02-18 09:52:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-18 09:52:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-18 09:52:31
Socket (2) | Shutdown and closed. | 2015-02-18 09:52:31
Rithmic Trading | Disconnected from the server. | 2015-02-18 09:52:31
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-18 09:52:31
Rithmic Trading | Bridge process is still running. | 2015-02-18 09:52:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57668 | 2015-02-18 09:52:35
Socket (3) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-18 09:52:36
Socket (3) | Shutdown and closed. | 2015-02-18 09:52:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-18 09:52:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-18 09:52:36
Rithmic Trading | Disconnected from the server. | 2015-02-18 09:52:36
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-18 09:52:36
Chart #2 has tagged chart #4 for full recalculation. Chartbook: Vermont Volume Traders ES.cht | 2015-02-18 09:52:36
Chart #4 is performing a full recalculation because it has been tagged. Chartbook: Vermont Volume Traders ES.cht | 2015-02-18 09:52:36
Study/Price Overlay DateTime: Array is unallocated. | 2015-02-18 09:52:37 *
Rithmic Trading | Bridge process is still running. | 2015-02-18 09:52:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57668 | 2015-02-18 09:52:40
Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-18 09:52:41
Socket (4) | Shutdown and closed. | 2015-02-18 09:52:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-18 09:52:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-18 09:52:41
Rithmic Trading | Disconnected from the server. | 2015-02-18 09:52:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-18 09:52:41
Rithmic Trading | Bridge process is still running. | 2015-02-18 09:52:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57668 | 2015-02-18 09:52:45
Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-18 09:52:46
Socket (5) | Shutdown and closed. | 2015-02-18 09:52:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-18 09:52:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-18 09:52:46
Rithmic Trading | Disconnected from the server. | 2015-02-18 09:52:46
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-18 09:52:46
Rithmic Trading | Bridge process is still running. | 2015-02-18 09:52:48
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57668 | 2015-02-18 09:52:50
Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-18 09:52:51
Socket (6) | Shutdown and closed. | 2015-02-18 09:52:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-18 09:52:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-18 09:52:51
Rithmic Trading | Disconnected from the server. | 2015-02-18 09:52:51
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-18 09:52:51
Study/Price Overlay DateTime: Array is unallocated. | 2015-02-18 09:52:52 *
Study/Price Overlay DateTime: Array is unallocated. | 2015-02-18 09:52:53 *
Rithmic Trading | Port for executable: 57684 | 2015-02-18 09:52:53
Listening socket (1864), port 57684 | Closed. | 2015-02-18 09:52:53
Rithmic Trading | Starting server: C:\SierraChart1\Rim\DTCBridge.exe | 2015-02-18 09:52:53
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57684 | 2015-02-18 09:52:55
Socket (7) | Connected. | 2015-02-18 09:52:55
Rithmic Trading | Connected to server. | 2015-02-18 09:52:55
Rithmic Trading | Sending logon request message. | 2015-02-18 09:52:55
Rithmic Trading | Starting the connection process to data and trading service. | 2015-02-18 09:52:55
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart1\Rim\Rithmic.log | 2015-02-18 09:52:55
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-02-18 09:52:55
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-02-18 09:52:56
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-02-18 09:52:56
Rithmic Trading | Server Name: DTC Bridge. | 2015-02-18 09:52:56
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-02-18 09:52:56
Rithmic Trading | Logon error from server | 2015-02-18 09:52:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-18 09:52:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-18 09:52:56
Socket (7) | Shutdown and closed. | 2015-02-18 09:52:56
Rithmic Trading | Disconnected from the server. | 2015-02-18 09:52:56
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-18 09:52:56
Rithmic Trading | Bridge process is still running. | 2015-02-18 09:52:58
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57684 | 2015-02-18 09:53:00
Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-18 09:53:01
Socket (8) | Shutdown and closed. | 2015-02-18 09:53:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-18 09:53:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-18 09:53:01
Rithmic Trading | Disconnected from the server. | 2015-02-18 09:53:02
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-18 09:53:02
Rithmic Trading | Bridge process is still running. | 2015-02-18 09:53:04
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57684 | 2015-02-18 09:53:06
Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-18 09:53:07
Socket (9) | Shutdown and closed. | 2015-02-18 09:53:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-18 09:53:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-18 09:53:07
Rithmic Trading | Disconnected from the server. | 2015-02-18 09:53:07
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-18 09:53:07
Rithmic Trading | Bridge process is still running. | 2015-02-18 09:53:09
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57684 | 2015-02-18 09:53:11
Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-18 09:53:12
Socket (10) | Shutdown and closed. | 2015-02-18 09:53:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-18 09:53:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-18 09:53:12
Rithmic Trading | Disconnected from the server. | 2015-02-18 09:53:12
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-18 09:53:12
Study/Price Overlay DateTime: Array is unallocated. | 2015-02-18 09:53:14 *
Rithmic Trading | Bridge process is still running. | 2015-02-18 09:53:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57684 | 2015-02-18 09:53:16
File >> Disconnect selected. | 2015-02-18 09:53:16
Socket (11) | Shutdown and closed. | 2015-02-18 09:53:16
Rithmic Trading | Disconnected from the server. | 2015-02-18 09:53:16
Study/Price Overlay DateTime: Array is unallocated. | 2015-02-18 09:53:21 *
[2015-02-18 18:04:26]
This is the relevant error message:
Refer to step 17 here for help with a permission denied error:
http://www.sierrachart.com/index.php?page=doc/OptimusRithmic.php#SetupInstructions
