Date/Time: Sun, 22 Dec 2024 05:21:11 +0000
IB Advisor account
View Count: 1055
[2015-02-18 09:05:16] |
EuropeanTrader - Posts: 290 |
Hi, I know you offer trading execution through InteractiveBrokers as well. Is is possible that I connect Advisor account and therefore I manage multiple accounts through one SC instance and with one click trading in the DOM ladder? tHANKS |
[2015-02-18 18:28:55] |
Yes. Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/IB.php#UsingFinancialAdvisorAccounts However, be aware there is not complete reliability with this feature and we do not provide support for it. So if you encounter problems, we are unable to help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
